izzzz
May 20, 2021Aspirant
ReadyNAS NV+ no power
My ReadyNAS NV+ suddenly stopped working, it won't turn on and theres no reponse from pressing the power button. I tried a diffrerent power cable but I think the power supply is dead. Is there any wa...
- May 20, 2021
izzzz wrote:
Is this guide good?
https://www.robdiesel.com/wordpress/2016/02/readynas-nv-frugal-power-supply-replacement/
I'll just do that now and I guess buy a new one soon.
It looks right, but it's not a procedure I've done myself (though I did do a replacement of the PSU in my own NV+, it was a warranty replacement). Hopefully Sandshark will chime in.
Note if you are just wanting to offload data, you can get by with a normal ATX supply, and make the pinout mod in a extension cable. The supply won't fit into the NAS, but it will work as a temporary measure
izzzz
Is this guide good?
May 20, 2021Guru - Experienced User
izzzz wrote:
Is this guide good?
