ncerniglia
Feb 19, 2017Aspirant
ReadyNAS NV+ Not Recognized on Network
My ReadyNas is not recognized by any devices on my wireless network. Here are the facts: It is listed on my network map on my router's utility page. My ReadyNAS is plugged directly into my rout...
Sandshark
Feb 19, 2017Sensei
You should be going to https://192.168.1.128/admin. It's odd that it doesn't show in RAIDar, though. Maybe you are runing a version too old for Win10?
- StephenBFeb 20, 2017Guru - Experienced User
Can you connect the PC via ethernet, and see if the behavior changes?
- ncernigliaFeb 22, 2017AspirantI'll try that. Do I need to power the ReadyNAS down first, or can I just unplug the ethernet cable from the router without shutting it down?
- StephenBFeb 22, 2017Guru - Experienced User
ncerniglia wrote:
I'll try that. Do I need to power the ReadyNAS down first, or can I just unplug the ethernet cable from the router without shutting it down?The idea is to connect the PC to the router, not disconnect the ReadyNAS.
I tried going to https://... but the behavior is the same. I'll try updating my version of RAIDar to see what that does.
UPDATE: I'm a slight idiot. I forgot about adding "admin" to the end of the IP address. When I did use "admin," I was able to get into Frontview. And once that happened, I was able to detect the ReadyNAS on my network, and map folders as network drives.However, RAIDar still does not detect it. I'm using RAIDar 4.3.8
