ncerniglia
Feb 19, 2017Aspirant
ReadyNAS NV+ Not Recognized on Network
My ReadyNas is not recognized by any devices on my wireless network. Here are the facts: It is listed on my network map on my router's utility page. My ReadyNAS is plugged directly into my rout...
Sandshark
Feb 19, 2017Sensei
You should be going to https://192.168.1.128/admin. It's odd that it doesn't show in RAIDar, though. Maybe you are runing a version too old for Win10?
Feb 20, 2017Guru - Experienced User
Can you connect the PC via ethernet, and see if the behavior changes?
- ncernigliaFeb 22, 2017AspirantI'll try that. Do I need to power the ReadyNAS down first, or can I just unplug the ethernet cable from the router without shutting it down?
- StephenBFeb 22, 2017Guru - Experienced User
ncerniglia wrote:
I'll try that. Do I need to power the ReadyNAS down first, or can I just unplug the ethernet cable from the router without shutting it down?The idea is to connect the PC to the router, not disconnect the ReadyNAS.
- ncernigliaMar 02, 2017Aspirant
When I connect the PC directly to the router, RAIDar can indeed see the ReadyNAS.
I assigned a permanent IP address to the ReadyNAS through my router. All devices (a PC and a Mac, and two Blu-ray players, and my Xbox One) on my network are able to see the ReadyNAS now, and RAIDar can now detect the ReadyNAS when my PC is only connected wirelessly. Everything seems to be going fine.Thanks for your help!
