KenQuek
Aug 22, 2016Aspirant
ReadyNAS NV+ Only fan powers on
One day it stucked at shutting down for 15minutes i assumed it hung. So after i switched off the mains and tried to hard reboot nothing happens, only the fan spin up. Fan spin up at very high rpm...
BrianL2
Aug 23, 2016NETGEAR Employee Retired
Hi KenQuek,
I am not certain if we still have stock for the PSU but take note that this is limited to certain countries or regions. In your case, your option is to rewire an ATX PSU or purchase a new OS 6 unit.
Kind regards,
BrianL
NETGEAR Community Team
bedlam1
Aug 23, 2016Prodigy
In case it helps, is it this PSU ?
https://www.amazon.co.uk/Netgear-Power-Supply-Unit-Ready/dp/B000W3X480
UK company, but they ship worldwide
- StephenBAug 23, 2016Guru - Experienced User
A somewhat cheaper one here: http://www.evercase.co.uk/CompatibilityListReadynas.htm
KenQuek: what country do you live in? Are you comfortable modifying the pinout, or would you rather purchase a PSU you can simply plug in?
- bedlam1Aug 23, 2016Prodigy
ooooopppps the one Stephen posted is the one I thought I had found (from memory) :smileyembarrassed:
- KenQuekAug 23, 2016Aspirant
Thanks all, i live in Singapore. Will probably try hooking to a modified ATX first to confirm it is not the mobo. In my case my fan still runs, but i really hope it is just the PSU.
