AA2769
Mar 07, 2014Aspirant
ReadyNAS NV (original) exhibits strange booting behavior
I have a 7 years old NV box made by Infrant with two 250GB Seagate Barracuda drives. I hadn't used it for a while, but felt suddenly motivated to build a personal cloud. So, last weekend, I fired it u...
Mar 07, 2014Guru - Experienced User
If the drives check out, try deleting the partitions on the drives on a PC (with windows, right-click on computer, select manage, and then delete the volume in the disk manager section). Or use the write test in seatools, which also effectively deletes the partitions.
