kbatzer
Oct 17, 2014Aspirant
ReadyNAS NV+ reboot keep failing
I've noticed that my original ReadyNAS NV+ (RND4000), purchased in 2009, has had trouble rebooting when initiated from the GUI. It would shutdown OK but consistently gets stuck on rebooting. The unit ...
vandermerwe
Oct 17, 2014Master
1. Check the disks smart information and consider removing and testing all the disks ( if you do do this, only remove and reinsert the disk with the nas off)
2. Delete ( don't download) all of your system and backup job logs.
Do you have a backup?
