tw
Jan 26, 2014Aspirant
ReadyNAS NV recovery questions?
I have had a NV for years and it recently went inaccessible. The NV has two 1TB Segate Barracuda drives installed. When I reboot, the NV hangs up with the power light pulsing, activity light off, a...
vandermerwe
Jan 26, 2014Master
Trying to boot with drive 2 is a reasonable first step.
If it is the drive then first backup your data.
Hot add new drive to bay 1
Allow resync
Hot swap drive in bay 2 with new good drive if you want to - I assume you are planning to increase size of drives. All long as the first one you put in is the same size or smaller than the second one you will be ok.
Post outcome.
Allow resync
Post outcome.
