LaCucaracha
Nov 18, 2021Aspirant
ReadyNAS NV+ (RND4000) - Volume expansion hung?
I have an old RND4000 which I'm in the process of expanding from it's original 4 x 1TB Seagate to 4 x 2TB Hitachi disks. I updated to RAIDiator 4.1.16 (most recent available for this old model) a...
LaCucaracha
RAIDar shows nothing because it's not reachable on the network.
From some other discussions, it almost sounds like this is stuck at some stage prior to the volume expansion happening? I saw a post where the display indicated expansion was in process (and stuck at 0% for a long time) ... mine is not even doing that. No drive LEDs lit, fan on full, power light blinking and front display message still at "Booting, please wait ...".
Safe to power off and power back on? If so, just hold the power button until it turns off or ?
Nov 18, 2021Guru - Experienced User
Sometimes it will - since it uses broadcast ethernet packets to get status, and not IP.
Not sure it's safe, but at some point you will have to. I'd hold the power button until it turns off.
