sbwga
Apr 02, 2016Follower
ReadyNAS NV+ (RND4000)- Will boot and sync volumes but will shut down 10-15 minutes after booting
I can boot the device and it will load fine. With no consistency, it will shut down some 10-15 minutes after booting. The power switch will not work again unless I unplug the power cable from the back of the unit and re-attach it. Then it will boot again....
PSU? Something else? The issue with the switch has me perplexed but the unit runs fine....until it doesn't.
Unit is clean, vacuumed, blown out with air, etc.
1 Reply
Do the logs say why it is shutting down?
