ML2000
Jan 19, 2016Aspirant
ReadyNAS NV+ (RND4000) Cannot create Raid 0 volume
I have a NV+ that was in RAID 0 and 2 HDD died. Data is backed up so not an issue, the system ran for >4 yrs no issues once setup. I had many issues with the original purchased unit so this product...
- Jan 19, 2016
The firmware is not the problem.
Are you using RAIDar 6.0? RAIDar 6.0 is meant primarily for our new devices. You could try using RAIDar 4.3.8 instead. Other users have found that resolved the problem for them.
Or you could simply delete the volume that is created using Frontview and then create the RAID-0 volume(s) you want. I would recommend a separate volume for each disk if you use RAID-0. With a RAID-0 volume if a single disk fails all data on the volume is lost.
BrianL2
Jan 19, 2016NETGEAR Employee Retired
Hi ML2000,
This is interesting. The system should allow you to create a single volume with (flex) RAID 0 as its configuration/type. Kindly try it again and check this documentation then turn to pages 3-7 to 3-9.
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
- ML2000Jan 20, 2016Aspirant
Switching to RAIDar 4.3.8 did the trick. Very confusing and I had to hunt down the software as not on Netear website, at least I could not find it.
Thanks
- StephenBJan 20, 2016Guru - Experienced User
Thanks
It is there, but harder to find than it should be. This page has it: http://downloadcenter.netgear.com/other/product/RNDP4420D#searchResults
A direct download is here: http://www.downloads.netgear.com/files/ReadyNAS/RAIDar_Win_4_3_8.exe
