nathor
Jan 25, 2016Aspirant
ReadyNAS NV+ RND4000 Capacity
Hello We have been running a ReadyNAS NV+ RND4000 for a number of years now, with just one 3TB drive. Running XRAID, we had 700GB of storage space. Recently, we needed to up that capacity, so...
- Feb 03, 2016
You're running the latest production firmware for your NV+.
The v2 uses very different hardware. The OS for the v2 won't run on the v1 and vice versa.
So you should either get 2TB disks for your NV+ v1 or get a new ReadyNAS (note the RAID format is different so the disks would need to be wiped by the new NAS).
Jan 25, 2016Guru - Experienced User
What firmware are you running?
If it is 5.x.x, then your NV+ is a v2 arm unit, which does support GPT formatted drives.
But from your symptoms, I think you are running 4.1.x firmware. Then your NV+ is a v1 sparc which does not support drives > 2 TB. 3 TB drives usually end up detected at around 700 GB.
If I am correct, you need to backup up the data, remove the existing drives and install 2 TB drives. 4x2TB would give you ~6 TB capacity with xraid.
Yes you will need to back it up - though with only 700 GB space, this should not be a major problem.
- mdgm-ntgrJan 26, 2016NETGEAR Employee Retired
You must have a v1. Every v2 firmware has GPT support so you would not have seen this issue on that.
