nathor's avatar
nathor
ReadyNAS NV+ RND4000 Capacity
Hello   We have been running a ReadyNAS NV+ RND4000 for a number of years now, with just one 3TB drive. Running XRAID, we had 700GB of storage space.   Recently, we needed to up that capacity, so...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Feb 03, 2016
    You're running the latest production firmware for your NV+.
    The v2 uses very different hardware. The OS for the v2 won't run on the v1 and vice versa.
    So you should either get 2TB disks for your NV+ v1 or get a new ReadyNAS (note the RAID format is different so the disks would need to be wiped by the new NAS).
ProSupport for Business
