nathor
Jan 25, 2016Aspirant
ReadyNAS NV+ RND4000 Capacity
Hello We have been running a ReadyNAS NV+ RND4000 for a number of years now, with just one 3TB drive. Running XRAID, we had 700GB of storage space. Recently, we needed to up that capacity, so...
- Feb 03, 2016
You're running the latest production firmware for your NV+.
The v2 uses very different hardware. The OS for the v2 won't run on the v1 and vice versa.
So you should either get 2TB disks for your NV+ v1 or get a new ReadyNAS (note the RAID format is different so the disks would need to be wiped by the new NAS).
nathor
Feb 02, 2016Aspirant
Thanks for the replies and sorry to take so long to get back -- I hadn't realised there were any replies (oops).
OK, so the firmware version running is 4.1.14. This is quite disappointing to learn, since hard drives here in Australia are far from cheap, which means the whole replacement thing isn't as easy as it could be.
Is there any way to update the firmware? I'm thinking that since neither of you offered that as a solution, this isn't a possibility...
mdgm-ntgr
Feb 03, 2016NETGEAR Employee Retired
- nathorFeb 03, 2016Aspirant
I thought that would be the case.
I had a look around at prices, comparing the cost of a new ReadyNAS vs replacing the disks, and the cost is roughly the same -- but, of course, we'd have far less space with 2TB disks than 3TB disks with a new NAS.
I am aware that the disks would need to be wiped by the new ReadyNAS -- overall, though, we're looking at the same timeframe, since e'd have to move all the data from the 3TB disks anyway.
Thanks very much for your help. It is rather a shame we hadn't realised this issue earlier on, but you live and you learn.
- StephenBFeb 03, 2016Guru - Experienced User
Since you already have the 3 TB drives, I think you are correct on the costs.
Note that the brand new RN3xx and above that were purchased from authorized resellers includes lifetime chat/email support. The RN2xx and below only include 90 day installation support (and of course the warranty). If you are using the NAS for a business, you should probably consider the RN312. That would give you 3 TB of RAID-1 storage with your existing disks (4x what you have today).
The NAS is used for business. We'll have to look into costing of the higher models, as you've suggested, and decide which one to go for.
Once again, I do appreciate the help here. It's much appricated.
