nathor
Jan 25, 2016Aspirant
ReadyNAS NV+ RND4000 Capacity
Hello We have been running a ReadyNAS NV+ RND4000 for a number of years now, with just one 3TB drive. Running XRAID, we had 700GB of storage space. Recently, we needed to up that capacity, so...
- Feb 03, 2016
You're running the latest production firmware for your NV+.
The v2 uses very different hardware. The OS for the v2 won't run on the v1 and vice versa.
So you should either get 2TB disks for your NV+ v1 or get a new ReadyNAS (note the RAID format is different so the disks would need to be wiped by the new NAS).
mdgm-ntgr
Feb 03, 2016NETGEAR Employee Retired
nathor
Feb 03, 2016Aspirant
I thought that would be the case.
I had a look around at prices, comparing the cost of a new ReadyNAS vs replacing the disks, and the cost is roughly the same -- but, of course, we'd have far less space with 2TB disks than 3TB disks with a new NAS.
I am aware that the disks would need to be wiped by the new ReadyNAS -- overall, though, we're looking at the same timeframe, since e'd have to move all the data from the 3TB disks anyway.
Thanks very much for your help. It is rather a shame we hadn't realised this issue earlier on, but you live and you learn.
