svbeers
Oct 13, 2016Aspirant
ReadyNAS NV+ RND4000 Capacity
hi to you all I want to upgrade my ram module to 1gb is this possible on this model ReadyNAS nv+2 4x 3tb from factory is 256mb installed on the nas can I upgrade the nas ????
Oct 13, 2016Guru - Experienced User
The NV+ v2 has the memory soldiered to the systemboard, so it is not upgradable.
svbeers
Oke Thanx for the information
Ps.
Is the ram module upgradable in solder form I know this is possible but support the nas the change to a higher ram module ?
- StephenBOct 13, 2016Guru - Experienced User
Netgear doesn't support memory upgrades on this NAS. I'm not sure how much memory the NV+ v2 would accept (assuming you could safely upgrade it).
- svbeersOct 13, 2016Aspirant
Oke thanks I will contact Netgear for future support on this matter thank you for you input
Sorry it wasn't a better answer for you.
The NV+ v2 is end-of-life, and there are newer OS-6 NAS that do have memory slots. Netgear still doesn't support upgrades, but some people do them anyway.
