mab45
Jan 09, 2012Tutor
Readynas NV+ slow performance despite best efforts!
[Setup / Devices] ReadyNAS NV+ / 1GB RAM - RAIDiator 4.1.8 [1.00a043], X-RAID, 4 disks SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB SATA 3.0Gb/s (3.5 of 5.4TB free) ASUS Black Diamond Gigabit A...
mab45
Jan 09, 2012Tutor
mdgm wrote: Download your logs (Status > Logs > Download all logs), what does your partition.log look like?
Do note that 3rd party memory upgrades are not supported.
I was not aware that adding the 1GB Memory was not supported. If you think removing the module might help, I'd be happy to try that. Please comment.
Also, I did notice there was a 4.1.9-T2 beta firmware that people were having some success with, so I updated mine. IOMeter still shows Read 4MB/s and Write 11MB/ps..
And here's a copy of my partition.log -- (THANKS in advance for any help!)
Disk /dev/hdi doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608002 3906992305 1951192152 5 Extended
/dev/hdc5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
/dev/hde1 2 4096001 2048000 83 Linux
/dev/hde2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hde3 4608002 3906992305 1951192152 5 Extended
/dev/hde5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
/dev/hdg1 2 4096001 2048000 83 Linux
/dev/hdg2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdg3 4608002 3906992305 1951192152 5 Extended
/dev/hdg5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
