mab45
Jan 09, 2012Tutor
Readynas NV+ slow performance despite best efforts!
[Setup / Devices] ReadyNAS NV+ / 1GB RAM - RAIDiator 4.1.8 [1.00a043], X-RAID, 4 disks SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB SATA 3.0Gb/s (3.5 of 5.4TB free) ASUS Black Diamond Gigabit A...
mab45
Jan 21, 2012Tutor
mdgm wrote: Do you still get this performance with the stock memory?
I just swapped back to my stock 256MB memory, and new speeds are Read 16Mbps and Write 22Mbps
Is this via a direct-connection with a known working Cat5e or newer ethernet cable?
Yes
Are the NIC drivers in your PC up to date?
Yes
And just for the record, after resetting the device, I've had similar speeds to this in the past, but then they reduce significantly to 6-12Mbp/s within 24 hours.
If they remain the same 16/22 Mbps speeds, am I supposed to be okay with that? Are my drives 4k aligned properly based upon my partition.log?
