mab45
Jan 09, 2012Tutor
Readynas NV+ slow performance despite best efforts!
[Setup / Devices] ReadyNAS NV+ / 1GB RAM - RAIDiator 4.1.8 [1.00a043], X-RAID, 4 disks SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB SATA 3.0Gb/s (3.5 of 5.4TB free) ASUS Black Diamond Gigabit A...
mab45
Feb 08, 2012Tutor
fbmachines wrote: Are you still running via a direct connection or are you going through a switch/router?
I'm back to going through my switch/router because I need my internet up and running for daily use. I tried the direct connection w/o a difference. I used a Linksys WRT320N router initially with no luck. So, just in case, I upgraded to the top-of-the-line ASUS Black Diamond RT-N56U. Same results as above after all the troubleshooting.
