gmhitchcock
Sep 29, 2014Aspirant
ReadyNAS NV+ (sparc) - OS Partition 100% - How to Fix
I've been unable to access NAS via Frontview. Can view shares and access via ssh. How do I clean up the OS? login as: root [email protected]'s password: Linux DelphiNAS 2.6.17.14ReadyNAS #1 We...
mdgm-ntgr
Sep 29, 2014NETGEAR Employee Retired
upnp-av.log is the log for ReadyDLNA.
Rather than removing it, I would do
/var/log/syslog and /var/log/daemon.log are also quite large. You may wish to copy those to the data volume (in case they contain something important) then empty them.
You may also wish to do e.g.
to see if there are any important messages in the log.
What about
Could be some large log files in there.
# echo "" > /var/log/upnp-av.log
# tail -n 100 /var/log/syslog
What about
# du -csh /var/log/frontview/*
