jbrit
Dec 10, 2014Aspirant
ReadyNAS NV+ stuck at 0% resync
Hi, Suffered a power outage yesterday. Restarted the NV+ and just left it overnight. Came back to it this morning and it was unresponsive to ping / radiar and frontview. LCD display was blank. ...
vandermerwe
Dec 10, 2014Master
Do you have a backup?
If not you should consider contacting Netgear support for paid support , otherwise try these things/ answer these questions.
Did you have ssh enabled?
I would wait for 24 hours and see if any progress is made.
If not I would power down then do an OS reinstall using the boot menu:
http://kb.netgear.com/app/answers/detai ... o5bQ%3D%3D
If that does not work, power down, remove and test all disks using vendor tools. Remember to label them according to slot number and do not power on again until they are all back in.
Buy yourself an uninterruptible power supply.
