jebr
Oct 01, 2012Aspirant
ReadyNAS NV+ Stuck at "Scheduled on" event after 4.1.10
Hello I successfully upgraded my NV+ to 4.1.10 one week ago. I have the power timer set to shut down the NAS at night and boot it each morning. On 4 mornings since the upgrade I have found the ...
koahnig
Oct 04, 2012Aspirant
I am facing the same problem.
I have been updating for 4.1.9 a couple of month ago. Sept 23 I have updated to 4.1.10 which went smoothly as the previous update. The NAS has also a schedule to power down overnight. After updating it went a couple of nights without problem, but after around 5 nights it did not boot properly in the morning. The unit is stored away, I have noticed when some tools have reported access problems after more than a day.
The symtoms as described above. The vent runs on low noise, but louder than in standard operation.
The only solution was to pull the power. The manual boot went without an issue. However, every morning the same procedure. Several times I had to repeat until successful boot. It never did a sync of the RAID disks. Seem to operate normally. I have disabled the scheduling.
I am wondering, if I should downgrade to 4.1.9. Is that possible? Or do I have to expect other problems?
@jebr Certainly, I would appreciate to know, if the reinstall 4.1.10 would solve the problem. Let me know, when you recovered enough to give it a try.
