jebr
Oct 01, 2012Aspirant
ReadyNAS NV+ Stuck at "Scheduled on" event after 4.1.10
Hello I successfully upgraded my NV+ to 4.1.10 one week ago. I have the power timer set to shut down the NAS at night and boot it each morning. On 4 mornings since the upgrade I have found the ...
vandermerwe
Oct 04, 2012Master
These problems are probably not related to the firmware.
I would suggest jebr, that you test disk 4 with vendor tools:
koahnig, you could try to reinstall firmware, I would not remove any disks just yet.
If you want help, I would suggest posting details of your setup.
