jebr
Oct 01, 2012Aspirant
ReadyNAS NV+ Stuck at "Scheduled on" event after 4.1.10
Hello I successfully upgraded my NV+ to 4.1.10 one week ago. I have the power timer set to shut down the NAS at night and boot it each morning. On 4 mornings since the upgrade I have found the ...
koahnig
Oct 05, 2012Aspirant
Thanks guys for feedback.
As being a SW engineer doing my own SW I certainly know that it might be a coincidence. However, it started shortly after upgrading. I have no experience with this forum, but I also expected to see more "noise" for a general problem with the release. On the other hand it would be interesting to know how many people are bothering to use scheduling.
Not thinking of the environment is helps in my case. At least the NAS stays happy so far.
There was everything alreight before upgrading. The only issues I had before were a disk reporting repeatably bad sectors. So I have replaced it. The other problem was when trying an add-on which killed the running installation. I ended up to do a factory reset. Luckily I was able to copy all stuff off the disk before.
I will follow your recommendation and reinstall.
