jebr
Oct 01, 2012Aspirant
ReadyNAS NV+ Stuck at "Scheduled on" event after 4.1.10
Hello I successfully upgraded my NV+ to 4.1.10 one week ago. I have the power timer set to shut down the NAS at night and boot it each morning. On 4 mornings since the upgrade I have found the ...
koahnig
Oct 16, 2012Aspirant
PapaBear wrote: Jebr and Koahnig - I do not note any mention of a current and complete backup of your units. Since both of you have experienced problems I would have thought that would be one of the first things you would do. With an current and complete backup you would then have the luxury of doing a factory default wiping the disks completely and reinstalling the firmware from scratch.
I was in the process of doing a backup. The downgrade to 4.1.9 did not help. After a couple of successful automatic boots in the morning I am back to square one. It failed this morning again. So, it is not simply a question of the version.
I am contemplating about doing a factory reset. The only advantage I see would be reset of any memory and settings not changed with new versions. Is this worth to do?
Are there some maintenance tools around for checking the HW?
