Danxter
May 29, 2017Aspirant
Readynas NV+ stuck on boot
Hello, I am encountering issues with my Readynas NV+ as it does not boot anymore. When launching it, the "checking quotas" phase ends up well but the booting phase cannot. I can stop the Nas with...
- Jun 03, 2017
Looks like your system is crashing attempting to download huge log files.
Danxter
Thanks for your reply.
I already tried to skip the volume checking. With no success.
Concerning Linux shell commands, I am not an expert. But I already used it many times so it depends on what it consists in...
May 29, 2017Guru - Experienced User
You'd boot up in tech support mode, and then mount the OS partition.
After that, you'd check the fullness, and (assuming it is full) resolve it by truncating logs and clearing the cache. If you can mount the C volume, then it is also possible to move folders of any add-ons you installed to the C volume, and replace the original with a sym link.
