eisberger
Oct 05, 2014Aspirant
ReadyNAS NV+ stuck on "Booting Please wait"
I'm having a very similar issue, though removing the disks had no effect. I had to move the NV+ as it was too loud in the location it was, so I shut it down correctly (waited for it to turn off by its...
Oct 05, 2014Guru - Experienced User
Often running multiple passes shows up failures that don't show up on the first.
The test continues until you stop it.
