eisberger
Oct 05, 2014Aspirant
ReadyNAS NV+ stuck on "Booting Please wait"
I'm having a very similar issue, though removing the disks had no effect. I had to move the NV+ as it was too loud in the location it was, so I shut it down correctly (waited for it to turn off by its...
Oct 05, 2014Guru - Experienced User
Certainly it makes sense to test them with WDC's lifeguard program (for the WDC drives) and Seatools (for the barracudas). At least run the short SMART tests.
mdgm wrote: Though I still think a problem with one of the disks is likely.
