eisberger
Oct 05, 2014Aspirant
ReadyNAS NV+ stuck on "Booting Please wait"
I'm having a very similar issue, though removing the disks had no effect. I had to move the NV+ as it was too loud in the location it was, so I shut it down correctly (waited for it to turn off by its...
Oct 06, 2014Guru - Experienced User
If you have multiple disk failures, then you are in a bad spot as far as data recovery goes.
Sometimes it is possible to "clone" a failing disk to a new one. However, that isn't always possible - certainly it isn't if the disk isn't readable at all. Even if it is mostly working, there is almost always some file system corruption/lost files.
