eisberger
Oct 05, 2014Aspirant
ReadyNAS NV+ stuck on "Booting Please wait"
I'm having a very similar issue, though removing the disks had no effect. I had to move the NV+ as it was too loud in the location it was, so I shut it down correctly (waited for it to turn off by its...
Oct 06, 2014Guru - Experienced User
The fact that it tried to boot with disk 4 removed suggests that disk 4 has failed - and in a way that would likely prevent cloning.
Disk 3 might also be degraded - the diagnostics should provide some useful information.
