eisberger
Oct 05, 2014Aspirant
ReadyNAS NV+ stuck on "Booting Please wait"
I'm having a very similar issue, though removing the disks had no effect. I had to move the NV+ as it was too loud in the location it was, so I shut it down correctly (waited for it to turn off by its...
Oct 06, 2014Guru - Experienced User
I'd boot it up without disk four.
eisberger wrote: Should I boot it up without disk 4 in then hotplug a new disk? Please be aware that I'm not touching anything until you guys tell me what to do <3
Then copy off at least critical data to another device.
When complete, hot-insert the new disk into slot 4.
