eisberger
Oct 05, 2014Aspirant
ReadyNAS NV+ stuck on "Booting Please wait"
I'm having a very similar issue, though removing the disks had no effect. I had to move the NV+ as it was too loud in the location it was, so I shut it down correctly (waited for it to turn off by its...
mdgm-ntgr
Oct 07, 2014NETGEAR Employee Retired
So perhaps there is a problem with slot 4. After you've got your data backed up this is something you can check.
