Midnightyell
Jan 08, 2016Aspirant
ReadyNAS NV+ syslogd taking 100% CPU
Hi -
I've got a Sparc-based ReadyNAS NV+ that I've had for years. Currently running RAIDiator 4.1.14; 4 x 2TB drives in Raid-X configuration, with about 300G/5.5T free.
Lately, the NAS box will become non-responsive during transfers and I have to pull the power, and re-install the OS in order to make it happy. Unfortunately, it's not happy for more than a few hours at a time lately, and I've had to do this once a day or so. By non-responsive, I mean that I can ping it, but not telnet/ssh/frontview, and the front-panel power-button seems to do nothing with a brief press.
I've bought its replacement, and am transferring ~ 6TB off it via CIFS, and it is still locking up.
This last time, I left top running in a terminal window, which was still updating, though slowly.
top - 18:24:58 up 1 day, 1:18, 1 user, load average: 9.04, 9.07, 9.02 Tasks: 67 total, 5 running, 62 sleeping, 0 stopped, 0 zombie Cpu(s): 1.6% us, 98.4% sy, 0.0% ni, 0.0% id, 0.0% wa, 0.0% hi, 0.0% si Mem: 226352k total, 221632k used, 4720k free, 8976k buffers Swap: 767904k total, 1856k used, 766048k free, 188352k cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1571 root 25 0 2128 960 800 R 97.7 0.4 1000:39 syslogd 1066 root 16 0 2992 1168 896 R 2.3 0.5 33:38.83 top 1 root 15 0 2000 592 496 S 0.0 0.3 0:05.09 init 2 root 34 19 0 0 0 S 0.0 0.0 0:00.03 ksoftirqd/0 3 root 10 -5 0 0 0 S 0.0 0.0 0:00.04 events/0 4 root 10 -5 0 0 0 D 0.0 0.0 0:00.03 khelper 5 root 10 -5 0 0 0 S 0.0 0.0 0:00.01 kthread 10 root 10 -5 0 0 0 S 0.0 0.0 0:09.36 kblockd/0 13 root 10 -5 0 0 0 S 0.0 0.0 0:00.01 khubd
Syslogd with 1000 minutes of runtime, and 98.4% sys CPU seems very likely to be the cause of my problem.
The rootfs wasn't full just prior to the CIFS transfer.
nasgul:~# df / -i Filesystem Inodes IUsed IFree IUse% Mounted on /dev/hdi1 128000 11330 116670 9% / nasgul:~# df / -h Filesystem Size Used Avail Use% Mounted on /dev/hdi1 1.9G 642M 1.3G 33% /
So, what's my next step here? A factory reset would be more palatable after I'm convinced that my data has been successfully backed up to the new NAS box.
What can I do to keep the box up while I do my transfers and verifications?
Thanks.
- mdgm-ntgrNETGEAR Employee Retired
Any clues from e.g.
# tail -n 20 /var/log/syslog
As to what is causing the syslog to max out the CPU?
You can try with more lines than 20 if 20 is not enough.
Sounds like something must be spamming the syslog. It would be very helpful to know what that is.The syslog daemon is the main daemon used for logging what happens on the NV+.
Do the SMART stats of the disks look fine?
- MidnightyellAspirant
SMART stats look okay. I can't check syslog without rebooting / reinstalling the OS, which clears syslog.
I'll run top/tail next time I reinstall to see what happens.
Please send me your logs (see the Sending Logs link in my sig).
