rjj296's avatar
rjj296
ReadyNas NV+ V1 Kernal Panic After FactoryReset and OS Reinstall
I have a readynas nv+ v1 (SPARC) from 2008 that started needing OS reinstalls whenever it froze. Finally it froze on a Disck Check and I determined that drive 3 was the issue. After pulling it, and e...
  • rjj296's avatar
    Oct 22, 2015
    I was able to resolve this by factory resetting, using RAIDar to format the drives, then re-factory resetting and using RAIDar to select my raid option (in this case RAID1).
ProSupport for Business
