borisw37
Feb 10, 2016Aspirant
ReadyNas NV+ V2 - Main volume not found (volume scan failed to run properly)
I have a ReadyNas NV+ V2. 4x2TB disks installed, 2 external USB drives for backup. Everything was running ok, then I shut it down and physically moved the NAS to a new location, new network. After...
borisw37
Feb 11, 2016Aspirant
Brian,
The drives were not removed/reinstalled.
*Log files sent.
Thank you,
Boris.
BrianL2
Feb 15, 2016NETGEAR Employee Retired
Hi borisw37,
I have seen events of disk failure dated last December, January and February. When you replaced these aformentioned disks (1&2) was the volume rebuilt and its data accessible afterwards? I suggest that you contact our support team to further check your system and they'll try to help you recover your data. Expect that there will be a fee for the said process.
Kind regards,
BrianL
NETGEAR Community Team
- borisw37Feb 16, 2016Aspirant
Brian,
Thank you for taking a look at the logs. Yes, my ReadyNAS would ocassional claim that one of the disks has failed, even though all of the SMART parameters were fine and the disk would work just fine (in an exteranl enclosure). So I had to occasionally remove/reinstall the "failed" disks and let NAS rebuild the volume.
Since I do have everything backed up from the NAS, is there anything quick / easy I can try for ReadyNAS to see the entire volume. I'm a bit oprehensive to spend any more money on the system since it's been a bit of a problem child from day 1.
Thank you,
Boris.
- BrianL2Feb 17, 2016NETGEAR Employee Retired
Hi borisw37,
You can try to mount your volume into a Linux machine and we have threads here in the community that could help. Since you have back up of every content or data from your ReadyNAS, why won't you just start over with a new set of drives or perhaps a new ReadyNAS system?
Kind regards,BrianL
NETGEAR Community Team- mdgm-ntgrFeb 17, 2016NETGEAR Employee Retired
You're using two ST2000DL003-9VT166 disks in slots 3 and 4.
These are known to drop out of RAID arrays with disk firmware older than CC3D. One of your disks (disk 4) has CC32 firmware and this can't be upgraded to CC3D firmware. The other disk 3 (has CC3C firmware) and this disk could be updated to CC3D firmware, but I would not update the firmware on the disk until all that can be recovered has been recovered off it.You also have a ST2000DM001 disk in the NAS and those disks are known to have high failure rates. Having said that the SMART stats for this disk look fine.
The data volume array won't currently start so it would require some work to get it back going again. If you try to fix it yourself you risk making the problem worse and reducing the chances of a professional attempt working.
