hiobeczek
Jan 14, 2015Aspirant
ReadyNAS NV+ V2 - NFS shares accessible only for 60 seconds
Hi all, My device: Model: ReadyNAS NV+ v2 Firmware: RAIDiator 5.3.11 I'm trying to test out NFS on my HTPC to see the difference between SMB, which for some reason keeps buffering movies in XBM...
mdgm-ntgr
Jan 18, 2015NETGEAR Employee Retired
What are you using a separate volume for each disk? You have no redundancy, so if a disk fails all the data on that disk is lost.
Can you send your logs (see the Sending Logs link in my sig)?
