hiobeczek
Jan 14, 2015Aspirant
ReadyNAS NV+ V2 - NFS shares accessible only for 60 seconds
Hi all, My device: Model: ReadyNAS NV+ v2 Firmware: RAIDiator 5.3.11 I'm trying to test out NFS on my HTPC to see the difference between SMB, which for some reason keeps buffering movies in XBM...
hiobeczek
Jan 20, 2015Aspirant
Yes, all the NFS shares act the same on all volumes. So if I disable NFS and re-enable or change the number of NFS threads all NFS shares will be accessible for 60 seconds with all sub folders accessible and then after 60 seconds I'm loosing access. only the top folders can be seen but I can;t get deeper into the folders and files.
