ddeadman
Jan 15, 2024Aspirant
ReadyNAS NV+ v2 - won't boot with more than 1 disk in
Hi there I recently wanted to erase all disks and start a fresh with my ReadyNAS unit. It's been great for 12+ years and worked flawlessly. After erasing all disks the unit refused to boot. ...
Jan 15, 2024Guru - Experienced User
ddeadman wrote:
After erasing all disks the unit refused to boot. I tried most things and eventually it sprang to life using only 1 disk in slot 1. I then had to do a factory reset and the unit boots no problem.
Try powering down and moving the disk to slot 2. Power up, and see if it boots. Repeat with slot 3 and slot 4.
