ddeadman
Jan 15, 2024Aspirant
ReadyNAS NV+ v2 - won't boot with more than 1 disk in
Hi there I recently wanted to erase all disks and start a fresh with my ReadyNAS unit. It's been great for 12+ years and worked flawlessly. After erasing all disks the unit refused to boot. ...
Jan 15, 2024Guru - Experienced User
ddeadman wrote:
After erasing all disks the unit refused to boot. I tried most things and eventually it sprang to life using only 1 disk in slot 1. I then had to do a factory reset and the unit boots no problem.
Try powering down and moving the disk to slot 2. Power up, and see if it boots. Repeat with slot 3 and slot 4.
ddeadman
Jan 16, 2024Aspirant
That was successful in 2 and 4. Although when in slot 3 the error message was “disk 1 failed”
- ddeadmanJan 16, 2024AspirantTo clarify, it actually says disk 1 failed when moving disk one to any of the other slots.
- StephenBJan 16, 2024Guru - Experienced User
ddeadman wrote:
To clarify, it actually says disk 1 failed when moving disk one to any of the other slots.Did you power down the NAS before moving the disk to the next slot, and then powered it up afterwards?
- ddeadmanJan 16, 2024AspirantYes I did power down each time.
Each time with disk 1 in slots 2, 3 & 4 it booted up ok and had an ip address.
