jaidank
Aug 09, 2013Aspirant
ReadyNAS NV+ v2 'no disk detected' after upgrade [SOLVED]
Having owned and loved a Duo v1 for many years I bought a pre-owned NV+ v2 without disks. I installed one of my ST3500418AS (500GB on HCL of both Duo and NV+ v2) in the NV+ and did a factory default...
mdgm-ntgr
Aug 09, 2013NETGEAR Employee Retired
Can you get it to boot into tech support mode?
