jaidank
Aug 09, 2013Aspirant
ReadyNAS NV+ v2 'no disk detected' after upgrade [SOLVED]
Having owned and loved a Duo v1 for many years I bought a pre-owned NV+ v2 without disks. I installed one of my ST3500418AS (500GB on HCL of both Duo and NV+ v2) in the NV+ and did a factory default...
jaidank
Aug 10, 2013Aspirant
mdgm wrote: So are your disks in the NAS?
Yes. Just one. I think its the one that scanned and installed perfectly the first time (before the failed upgrade) and installed perfectly in the Duo V2.
I read your 'Re: Another 'Booting..." NV+ issue' and understand that debug mode is only accessible by Netgear support. I don't suppose you have the required skills and inclination? I have set up port mapping on my router and could share my IP (effective) address with you via PM. Not to mention reboot it in debug mode again (its off atm).
Should I install the second ST3500418AS too?
PS: just saw your PM. On this boot (DebugMode) there is no disk let lit.
Will try hot unplug/plug (is that safe in debug mode)
All help appreciated.
Aidan
