ScottIon
Mar 27, 2017Aspirant
ReadyNAS NV+ v2 not booting - fast blinking Backup button light
Can anyone provide me with the right config of the USB Recovery Utility for my NAS? Not sure if it's x86, Marvell, or Annapurna. The symptoms are similar to this thread: https://community.netgear...
Ki_Adi_Mundi
Mar 29, 2017NETGEAR Employee Retired
Did you try unplug the power and wait several minutes and boot again ? See Here , the box boot again.
Also did you try boot the box w/o drives ? if there are things showing up on LCD, then you may not need usb recovery.
ScottIon
Apr 02, 2017Aspirant
It does boot w/o drives - I get an "ERR - No disks detected" on the LCD.
When I re-installed disks 1-3 (leaving the 4th drive out), I got the same blinking backup light.
Is there a recommended recovery process based on my situation?
Thanks!
