ScottIon
Mar 28, 2017Aspirant
ReadyNAS NV+ v2 not booting - fast blinking Backup button light
Can anyone provide me with the right config of the USB Recovery Utility for my NAS? Not sure if it's x86, Marvell, or Annapurna. The symptoms are similar to this thread: https://community.netgear...
ScottIon
Apr 02, 2017Aspirant
It does boot w/o drives - I get an "ERR - No disks detected" on the LCD.
When I re-installed disks 1-3 (leaving the 4th drive out), I got the same blinking backup light.
Is there a recommended recovery process based on my situation?
Thanks!
FramerV
Apr 03, 2017NETGEAR Employee Retired
Hi ScottIon,
Given the error, the NAS seems to be okay. Would be best to test the hard drives via a disk utility. You would need to connect the drives to a PC though.
