robbarber87
Oct 17, 2013Aspirant
Readynas NV+ v2-Slow Network Transfer Speed
Hi All, I have gone through pages and pages of forums but are all about specific instances and there are no tutorials or help guides as such that are helpful to me in my situation, so i hope somone...
Oct 17, 2013Guru - Experienced User
If you log into your router's admin web page, you should be able to see the status of each ethernet connection.
robbarber87 wrote: Oh sorry my mistake, how would i check this?
You have a virgin media superhub? They seem to do a good job of hiding their router manuals. But there is a guide here you can use http://help.virginmedia.com/system/self ... TYPE=Cable
Once you've logged in, you should be able to find the LAN status in the device status or advanced device status somewhere.
Perhaps a faster way is to look at the ethernet status lights on the back of the hub. They are described here: http://help.virginmedia.com/system/self ... TYPE=Cable
Green -> gigabit
Amber -> 100 mbit.
