alt1
Jan 22, 2013Aspirant
ReadyNAS NV+ v2 won't work with WD HDD's
Hi all, Here's the situation... Bought a new ReadyNAS NV+ v2 with latest firmware installed 5.3.7 Installed 2 x WD HDD's 1TB each WD10EZRX First boot-up everything went fine and was using the ...
mdgm-ntgr
Jan 22, 2013NETGEAR Employee Retired
You should have bought the WD RED WD10EFRX. Caviar Green disks are designed with features which make them a bad choice for RAID use.
