alt1
Jan 22, 2013Aspirant
ReadyNAS NV+ v2 won't work with WD HDD's
Hi all, Here's the situation... Bought a new ReadyNAS NV+ v2 with latest firmware installed 5.3.7 Installed 2 x WD HDD's 1TB each WD10EZRX First boot-up everything went fine and was using the ...
mdgm-ntgr
Jan 22, 2013NETGEAR Employee Retired
You could try running WDIDLE3 in your PC or if you can get the NAS to boot and are comfortable with SSH use the tool here: viewtopic.php?f=11&t=59700
It'd be better to put the Green disks in USB enclosures and use them as backup disks.
