alt1
Jan 22, 2013Aspirant
ReadyNAS NV+ v2 won't work with WD HDD's
Hi all, Here's the situation... Bought a new ReadyNAS NV+ v2 with latest firmware installed 5.3.7 Installed 2 x WD HDD's 1TB each WD10EZRX First boot-up everything went fine and was using the ...
alt1
mdgm wrote: You could try running WDIDLE3 in your PC or if you can get the NAS to boot and are comfortable with SSH use the tool here: http://www.readynas.com/forum/viewtopic.php?f=11&t=59700
It'd be better to put the Green disks in USB enclosures and use them as backup disks.
This NAS needs to be 100% reliable. I will bite the bullet and get some Red disks. Thanks for the info - expensive lesson learned
-EDIT- I'm goin gto give it a try regardless, just for educational sake. Can you advise on what settings need to be altered?
Thank you for your help
