alt1
Jan 22, 2013Aspirant
ReadyNAS NV+ v2 won't work with WD HDD's
Hi all, Here's the situation... Bought a new ReadyNAS NV+ v2 with latest firmware installed 5.3.7 Installed 2 x WD HDD's 1TB each WD10EZRX First boot-up everything went fine and was using the ...
alt1
mdgm wrote: You'd need to increase the number of seconds for the WDIDLE3 timer. The disks put themselves to sleep far too quickly for RAID use.
Thanks, I have checked a guideline which recommended 300 seconds.
There was also another WD application (Not Lifeguard, but a DOS one) that I Googled earlier... of course it's gone out of my head. Something like WDLDP (grrrr!) => Would appreciate any advise you can offer there
