alt1
Jan 22, 2013Aspirant
ReadyNAS NV+ v2 won't work with WD HDD's
Hi all, Here's the situation... Bought a new ReadyNAS NV+ v2 with latest firmware installed 5.3.7 Installed 2 x WD HDD's 1TB each WD10EZRX First boot-up everything went fine and was using the ...
alt1
mdgm wrote: Do you mean WDTLER? That shouldn't be necessary to use as the ReadyNAS has added compatibility for WD drives that don't support TLER
OK Thanks, I am going to try WDIDLE3
