alt1
Jan 22, 2013Aspirant
ReadyNAS NV+ v2 won't work with WD HDD's
Hi all, Here's the situation... Bought a new ReadyNAS NV+ v2 with latest firmware installed 5.3.7 Installed 2 x WD HDD's 1TB each WD10EZRX First boot-up everything went fine and was using the ...
mdgm-ntgr
Feb 02, 2013NETGEAR Employee Retired
RAIDar should indicate the progress. Can you try installing that on your PC, running it and hovering your mouse over the volume LED?
