alt1
Jan 22, 2013Aspirant
ReadyNAS NV+ v2 won't work with WD HDD's
Hi all, Here's the situation... Bought a new ReadyNAS NV+ v2 with latest firmware installed 5.3.7 Installed 2 x WD HDD's 1TB each WD10EZRX First boot-up everything went fine and was using the ...
Feb 02, 2013Guru - Experienced User
If you don't have a current backup, it would be a good time to make one (since your volume is not redundant, there is a higher risk of loss than usual).
Are there any hints in the log files? Also, have you submitted a support request?
